Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Fitting door seals advice video help...
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="vinvan" data-source="post: 587074" data-attributes="member: 20001"><p>They sound like the cheaper ones, bought mine from C&C £55 each (Stock Code: S01230 / OEM Part Number: 211831721D) the ones you have may be ok you will just have to fit them and see, but then you wont be able to send them back, at first i fitted the cheaper ones "not a good fit" the OEM seals are made from softer rubber and once bedded in they fit perfect</p></blockquote><p></p>
[QUOTE="vinvan, post: 587074, member: 20001"] They sound like the cheaper ones, bought mine from C&C £55 each (Stock Code: S01230 / OEM Part Number: 211831721D) the ones you have may be ok you will just have to fit them and see, but then you wont be able to send them back, at first i fitted the cheaper ones "not a good fit" the OEM seals are made from softer rubber and once bedded in they fit perfect [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
