Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Front seat replacement options
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ozziedog" data-source="post: 628868" data-attributes="member: 13810"><p>Not sure on new ones apart from second hand parts but even seat frames go for good money nowadays. Avoid bodge though to save your rear portions from continual spearing is a large electrical chocolate block style. I’ve even seen these in brass / copper in larger installations. Getting a friend or family member to fit one of these should be a simple enough process because the seats pop out easily enough to turn them over. Another bodge I’ve seen, is to cut out one of the horseshoe bends and stretch the spring a tad then put a tight piece of pipe over the two straight bits and secure, even gaffer tape will hold it. :mrgreen: </p><p></p><p>Ozziedog,,,,,,,,,,good atbodges me,,,, nuffink else though :mrgreen: <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /> :mrgreen:</p></blockquote><p></p>
[QUOTE="ozziedog, post: 628868, member: 13810"] Not sure on new ones apart from second hand parts but even seat frames go for good money nowadays. Avoid bodge though to save your rear portions from continual spearing is a large electrical chocolate block style. I’ve even seen these in brass / copper in larger installations. Getting a friend or family member to fit one of these should be a simple enough process because the seats pop out easily enough to turn them over. Another bodge I’ve seen, is to cut out one of the horseshoe bends and stretch the spring a tad then put a tight piece of pipe over the two straight bits and secure, even gaffer tape will hold it. :mrgreen: Ozziedog,,,,,,,,,,good atbodges me,,,, nuffink else though :mrgreen: ;) :mrgreen: [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
