Moseley said:We have coilovers fitted as we’re running reasonably low with no arch modification. I needed to stiffen the suspension due to the lack of wheel travel available, and coilovers have helped a great deal with that. There will be folks who just fit stiff shocks to combat the issue, but my personal feeling / experience on this is that you end up with springs that behave like stock, but shocks that are over-dampening and you end up with a pogo stick ride. If you do go down the coilover route and search for the ‘Gaz shock thread’ on here, I have a set of springs that are no longer required, so would just need some new shock bodies to pair with them.
Alternatively, if you’re stock height, go with an anti-roll bar, but I’m not sure how low you can go before these cause fitment / clearance issues.
fallingoffalot said:Moseley said:We have coilovers fitted as we’re running reasonably low with no arch modification. I needed to stiffen the suspension due to the lack of wheel travel available, and coilovers have helped a great deal with that. There will be folks who just fit stiff shocks to combat the issue, but my personal feeling / experience on this is that you end up with springs that behave like stock, but shocks that are over-dampening and you end up with a pogo stick ride. If you do go down the coilover route and search for the ‘Gaz shock thread’ on here, I have a set of springs that are no longer required, so would just need some new shock bodies to pair with them.
My front is fairly low on adjusters and drop spindles, and I have a stock anti-roll bar on a 4" narrowed beam. When I got my bus, May 2019, it had Red-9 coil-overs only and no stock springs. The ride was always too harsh no matter what adjustments I made, so I had the beam fitted. If you have adjusters then you may be able to make the ride firmer.
