Stevec
Sorry me again guys, I've only been an owner for a few months so its still all new to me.
The front suspension- I've just had a new adjustable front beam fitted and the mechanic set it up the same as the old height which has been lowered but sensibly ( not low as a rat) but it now seems to have no suspension in it at all, any small hole in the road and it will bang down with no spring in it at all, is that normal ? Can the suspension be adjusted or do I need to get different shocks? It seemed fine before but the mechanic noticed it had been cut and re welded (probably in the USA where it came from) so it was not safe.
Scat Shifter- I had this shifter installed because it kept going into reverse plus the 2nd gear crunched so thought this would cure it. I had all the bushes etc changed also. Now I've got it back I'm finding it hard to find 1st, usually finding 3rd (not great at the traffic lights). Also it's going into reverse still without even lifting the trigger, plus 2nd is still crunching?? I think the shifter needs adjusting again, but with the 2nd gear I'm not sure what to try next the clutch or gearbox???
