Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Fuel pump pedestal cracked?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="matty74" data-source="post: 645433" data-attributes="member: 21991"><p>Mine did the same when I was doing the seals recently. It was broken further up (probably been like that for a while) and I managed to retrieve the lower section using a M10 tap. The replacement I had wasn’t bakolite but seemed fairly decent (time will tell) I found a few fragments of bakolite when I dropped the oil soon after.</p></blockquote><p></p>
[QUOTE="matty74, post: 645433, member: 21991"] Mine did the same when I was doing the seals recently. It was broken further up (probably been like that for a while) and I managed to retrieve the lower section using a M10 tap. The replacement I had wasn’t bakolite but seemed fairly decent (time will tell) I found a few fragments of bakolite when I dropped the oil soon after. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
