Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Fuel pump wiring
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="KateLovesPurple" data-source="post: 427997" data-attributes="member: 743"><p>Yeah, no problem.</p><p></p><p>From the battery, through the fuse, through the inertia switch through the switched contacts on the relay, to the pump.</p><p></p><p>Hope that makes sense.</p></blockquote><p></p>
[QUOTE="KateLovesPurple, post: 427997, member: 743"] Yeah, no problem. From the battery, through the fuse, through the inertia switch through the switched contacts on the relay, to the pump. Hope that makes sense. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Fuel pump wiring
