Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Fuel Starvation
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ozziedog" data-source="post: 615571" data-attributes="member: 13810"><p>Easy check for fuel pressure with pipe off carb and placed into a clear large water bottle laying on its side , squirt on cranking should hit the bottom of a large water bottle(1.5-2L) then you can work forward from that point towards carb or back to the pump and or blockages in the tank but gives you a great starting point. New pipes are always worth checking visually too internally for a general idea of condition and taking off and blowing through for peace of mind.</p><p></p><p>Ozziedog,,,,,,,,,, fuel pumps are pants nowadays :mrgreen:</p></blockquote><p></p>
[QUOTE="ozziedog, post: 615571, member: 13810"] Easy check for fuel pressure with pipe off carb and placed into a clear large water bottle laying on its side , squirt on cranking should hit the bottom of a large water bottle(1.5-2L) then you can work forward from that point towards carb or back to the pump and or blockages in the tank but gives you a great starting point. New pipes are always worth checking visually too internally for a general idea of condition and taking off and blowing through for peace of mind. Ozziedog,,,,,,,,,, fuel pumps are pants nowadays :mrgreen: [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Fuel Starvation
