Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Fumes in the bus
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Red Bus" data-source="post: 528684" data-attributes="member: 21446"><p>Heat exchangers - check the join between the heat exchangers and the pipe - held by a small bracket that comes loose. Check the engine door seal. Also check for any holes in the engine bay that may leak fumes into the cab (mine has had screws put in it!). Also check that he pipes from the heat exchangers under the bus don't have holes in them.</p><p></p><p>Best of luck!</p><p></p><p></p><p>Sent from my iPad using Tapatalk</p></blockquote><p></p>
[QUOTE="Red Bus, post: 528684, member: 21446"] Heat exchangers - check the join between the heat exchangers and the pipe - held by a small bracket that comes loose. Check the engine door seal. Also check for any holes in the engine bay that may leak fumes into the cab (mine has had screws put in it!). Also check that he pipes from the heat exchangers under the bus don't have holes in them. Best of luck! Sent from my iPad using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Fumes in the bus
