Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Gear selection
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Alex VW Heritage" data-source="post: 535437" data-attributes="member: 19109"><p>Loosen off the the rearmost bolt that fixes the shifter itself to the floor, shift the rear of the shifter plate a few mm to the left and re fasten, it will most likely now be down to shifter adjustment. If you cant you may need to elongate the holes to give you more adjustment.</p></blockquote><p></p>
[QUOTE="Alex VW Heritage, post: 535437, member: 19109"] Loosen off the the rearmost bolt that fixes the shifter itself to the floor, shift the rear of the shifter plate a few mm to the left and re fasten, it will most likely now be down to shifter adjustment. If you cant you may need to elongate the holes to give you more adjustment. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Gear selection
