Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Generator light coming on
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="slow-lane-Matt" data-source="post: 624264" data-attributes="member: 19329"><p>interesting... I suppose this means the leisure battery is always being charged when engine is running, as opposed to using terminal 61 which will only energise relay and charge L battery when the correct o/p voltage is reached.</p><p></p><p>So with the coil both batteries are always being charged equally so takes longer to charge engine battery as half current always going to L battery. With T61, the engine battery is charged first, then the L battery.</p><p></p><p>I suppose in reality this doesn't make much difference, but probably best not to run the L battery right down or it may take charge from the engine battery (and vica versa)</p></blockquote><p></p>
[QUOTE="slow-lane-Matt, post: 624264, member: 19329"] interesting... I suppose this means the leisure battery is always being charged when engine is running, as opposed to using terminal 61 which will only energise relay and charge L battery when the correct o/p voltage is reached. So with the coil both batteries are always being charged equally so takes longer to charge engine battery as half current always going to L battery. With T61, the engine battery is charged first, then the L battery. I suppose in reality this doesn't make much difference, but probably best not to run the L battery right down or it may take charge from the engine battery (and vica versa) [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
