Having searched about there seems to be a mismatch of information flying around on this subject, so im hoping this thread will be a guide for me and others in the future.
So, if you have done this or know how to do it this is the thread for you to get posting on!
I have a CP Code 091 6Rib Box currently sat in the garage that i want to get fitted ASAP but as i dont want the bay off the road for long when i make the swap i would like to know what exactly needs to done, any problems that may be encountered, what parts can be used off the existing van and what new parts will need to be sourced.
Questions that seem to be common but with very few definitive answers:
Does the bellhousing on a CP box need to be changed to connect to an EB Engine?
If yes is the bellhousing off the EB Box transferable?
If the bellhousing is ok, what thrust bearing do you use?
Is the thrust bearing off an EB Box trasferable?
Do you have to change the clutch/flywheel to a later bay type?
What starter motor needs to be used....Late bay 2ltr or the one off your EB?
If you have to use a 2ltr starter does the flywheel on an EB engine need to be changed to a later one?
Do you need to weld in late bay gearbox hangers or can you run without them like a normal EB?
Are the bolt patten on the CV joints the same.....is it just a case of bolt em up or does somthing need to be modified/changed?
Ive read that 2ltr Bay CP 6 Rib Box is "longer" - is this the body of the gearbox, the gear selector, imput shaft or all of the above?
What issues does fitting this "longer" gearbox cause and how does this affect fitting?
What is the imput shaft....is this the shaft that sticks out of the bellhousing and attaches to the clutch?
How much does the imput shaft need to be shortened by?
How do you shorten it.....is it just a case of choping it off with a hacksaw?
If the box is longer will i need to cut down the selector shaft or gear selector rod to get all gears?
Questions, Questions!
I will be doing this shortly and will post up my progress but If you can help or have any advise please post it up.
Cheers,
Tony
Cheers,
Tony
