Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Hand brake problem on 68 and method of adjusting rear brake
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="baj25" data-source="post: 359984" data-attributes="member: 16034"><p>I had an MOT advisory on handbrake last year, so before test this year I roughed up the linings (they were glazed) and same on inside of drum. I found an easy way to grease the cables was to disconnect at lever end, pull through drum backplate as far as they would go (mine wouldn’t come all the way out), clean up cable and slap grease on while pushing the cable back in. It made a big difference, handbrake actually holds on medium slopes now. Otherwise, procedure is pretty much as you describe. HTH, Bri</p></blockquote><p></p>
[QUOTE="baj25, post: 359984, member: 16034"] I had an MOT advisory on handbrake last year, so before test this year I roughed up the linings (they were glazed) and same on inside of drum. I found an easy way to grease the cables was to disconnect at lever end, pull through drum backplate as far as they would go (mine wouldn’t come all the way out), clean up cable and slap grease on while pushing the cable back in. It made a big difference, handbrake actually holds on medium slopes now. Otherwise, procedure is pretty much as you describe. HTH, Bri [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
