Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Gallery
Happiness is a hot VW !
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Jackson’s Bus" data-source="post: 600510" data-attributes="member: 26430"><p>I got mine from EBay , if you search Eberspacher D2 you’ll find loads . There are 12v and 24v models too so best to get the 12 v one . The 24 v ones are a lot cheaper but you would either need a converter or an extra 12v battery . I couldn’t find a petrol one second as most come from diesel vans . I have an extra 10 litre fuel tank for the diesel. They use 0.3 litres an hour so you can easily run it for long trips and overnight stays . I ve also added a leisure battery so the bus will always start .</p></blockquote><p></p>
[QUOTE="Jackson’s Bus, post: 600510, member: 26430"] I got mine from EBay , if you search Eberspacher D2 you’ll find loads . There are 12v and 24v models too so best to get the 12 v one . The 24 v ones are a lot cheaper but you would either need a converter or an extra 12v battery . I couldn’t find a petrol one second as most come from diesel vans . I have an extra 10 litre fuel tank for the diesel. They use 0.3 litres an hour so you can easily run it for long trips and overnight stays . I ve also added a leisure battery so the bus will always start . [/QUOTE]
Verification
Post reply
EarlyBay Forums
Gallery
