Headlight dimmer switch not working
lcfmonkey
Oct 9, 2011
182
Brighton
It's been a while since I've driven in the dark but I went for a dusky drive yesterday and found I can't dip my lights, or rather when I pull up on the indicator stalk nothing happens! Is it time for a new stalk or is there something specific I should be looking for if I dismantle the indicator?
Cheers Peeps
Monkey
67westy
May 10, 2010
3,037
14
Lincoln
Happened to me before and it was an earth in the stalk that needed resoldering. See if you have any wires come loose
May 29, 2022
15
10
Newcastle-upon-Tyne
Year of Van
1971
Van Type
Microbus
Whilst replacing the loom in my 1970 bus, I also replaced the main/dipped/indicator stalk, and found the main/dipped connector on the stalk switch assembly wasn't actually connecting, and needed slightly bending - not great for a supposedly new item.
Maybe worth checking after the other suggestions above.
mike202
Sep 3, 2011
2,252
214
Northumberland
Similar thing happened on mine. Had dipped beam but no main beam or flash. After several hours investigating decided to check the new fuse box. There’s an earth fuse which had blown- problem solved
67panel
Jul 30, 2009
2,521
23
malven
Do the headlights flash, if so nothing wrong with switch it will be relay or fuse to dip beam
