Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Headlight flasher
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Moseley" data-source="post: 600852" data-attributes="member: 20098"><p>Ah bugger, that’s a shame, maybe someone else already removed it. The blue tell-tale is dimmer than the other lights due to the nature of how dark the filter is, but should be easy to see at night. Have you tried swapping the bulbs and bulb holders around to see if it’s a just a dim lamp?</p><p></p><p>I must admit, when recently re-wiring my van, I did upgrade the dash circuit wiring so that I could fit bulbs with double the wattage, and that has really helped with the back-lighting. Don’t think I did the tell-tales, just the back-lights... memory failing me</p><p></p><p></p><p>Sent from my iPhone using Tapatalk</p></blockquote><p></p>
[QUOTE="Moseley, post: 600852, member: 20098"] Ah bugger, that’s a shame, maybe someone else already removed it. The blue tell-tale is dimmer than the other lights due to the nature of how dark the filter is, but should be easy to see at night. Have you tried swapping the bulbs and bulb holders around to see if it’s a just a dim lamp? I must admit, when recently re-wiring my van, I did upgrade the dash circuit wiring so that I could fit bulbs with double the wattage, and that has really helped with the back-lighting. Don’t think I did the tell-tales, just the back-lights... memory failing me Sent from my iPhone using Tapatalk [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Headlight flasher
