Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Headlights
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Bluesnailman" data-source="post: 615589" data-attributes="member: 17859"><p>Poor headlights are a function of both the light/bulb units AND the voltage that reaches them. </p><p></p><p>A better bowl and lense will make the most of the voltage, but poor connections, old switches and thin wires will limit performance. Upgrading your wiring and using relays on a high voltage circuit and your existing light switch to trigger those relays will probably give you another 10%</p><p></p><p>For what it's worth, I had sealed units and changed them for clear lense golf sealed units and felt that made a difference. Also changed my wiring too.</p></blockquote><p></p>
[QUOTE="Bluesnailman, post: 615589, member: 17859"] Poor headlights are a function of both the light/bulb units AND the voltage that reaches them. A better bowl and lense will make the most of the voltage, but poor connections, old switches and thin wires will limit performance. Upgrading your wiring and using relays on a high voltage circuit and your existing light switch to trigger those relays will probably give you another 10% For what it's worth, I had sealed units and changed them for clear lense golf sealed units and felt that made a difference. Also changed my wiring too. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Headlights
