Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Help...back firing, loss of power - NOW TRUELY PI$$ED
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BJ1" data-source="post: 375617" data-attributes="member: 355"><p>Indeed! I've seen a couple of examples of this over the past few years, some caused by engine 'builders' using those Mex heads with the long reach plugs (so-called "unleaded heads"). They are thicker than normal and require longer pushrods to restore the geometry.</p></blockquote><p></p>
[QUOTE="BJ1, post: 375617, member: 355"] Indeed! I've seen a couple of examples of this over the past few years, some caused by engine 'builders' using those Mex heads with the long reach plugs (so-called "unleaded heads"). They are thicker than normal and require longer pushrods to restore the geometry. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
