Back from 600 mile round trip to Dubs at the Castle, bus ran sweet on dual carriageway, but idling was very iffy.
Just checked the carb - cleaned it with carb cleaner - in advance of the tuner coming tomorrow. Checked No 4 plug and perfect colour. Went to try the engine, ran rough for couple of seconds. Tried again, and I'm not sure whether I was still cranking or it was running, but it stopped stone dead, with a squeak (I assume from the still spinning dynamo). The crank is totally locked. Then noticed I hadn't put on the No 4 spark lead.
Out of desperation, tried rocking back and forward in gear, and tapping the starter motor with a mallet, just in case it's a jammed starter. But nowt. Crank is locked solid. Turning the ignition just gives a click.
What have I done????
Nick
Nick
