help please vans not well
69 panel porn
Apr 28, 2009
58
hi there im having trouble with my camper as its not running correct its missing and some times back firing i took it to the garage and the said it was the distributor so i sat with the engine running slowly adjusting the distributor and i could hear the engine pick up and then run pap again and it felt like the engine was knockin from the inside not makin a noise just judering so im thinking of changing the distributor,, but i was just wanting to see if any of you guys no of any thing else it could be
please can any 1 help :shock:
Could be the condenser on the side of the dizzy? Only a couple of quid so worth a try before you buy a new dizzy :?:
change the points and condenser if its a vac advance check that and then set the timming with a timming gun unless you can get hold of a dwell meter might be worth checking the valve clearance as well :mrgreen:
Sounds like its back to basics time - so checking plugs and points (and I guess valve clearances (on a stone cold engine)) then timing. Have the garage done any checks? Worth using a dwell meter to finely adjust the points gap - on my engine, it is quite sensitive to the gap adjustment. And a timing light to get the timing as good as possible. Is it an 009 or vac advance? If the latter, a gentle suck on the vac advance pipe to check that it is advancing is worth doing too.
Nick
the dizzy that was fitted was a 009 but its got elctronic point so i dont have to adjust them,
i changed the dizzy today and got it running the best i could with the short time i had as ive moved it so i can get to work on it with my friend,,
if i got a timing light is it easy to set it up by my self??
and how do i check the valve clearence??
thanks sam :oops:
Well, if I were you I'd seek out a decent engine tuner in your area who is known to be good with air-cooled. There's a brilliant chap in Ipswich who came round and set mine up after I'd tweaked and tweaked. He had the benefit of a gas analyser, which does help. But he also showed me the ropes - what makes a big difference, what doesn't etc. So I should be able to do a lot more myself. Best £70 I've spent on the van - and if I need him again, I know what to do so that he just does the final bit with the analyser - so it'll be £20-30 then.
If you are going to do it yourself, then I recommend you get a Bentley manual if you haven't already - although the timing data in that is confusing, so ignore it and ask on here. I set mine to 7.5 degrees BTDC at idle, rising to around 30 degrees at 3000rpm. I bought a fancy timing light with changeable settings for that - which were crap, so i ended up going the tippex route anyway, with a blob at 7.5, and a blob at 30 degrees. The manual will also tell you about checking the valve clearances.
Cheers,
Nick
