Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
help with alternator removal
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Happystamps" data-source="post: 528614" data-attributes="member: 14679"><p>Drop the engine, every time. Much easier, especially with the luxury of a removable valance. Doesn't matter to me if it takes an extra 20 minutes.</p><p></p><p>Aluminium casting ends off, pre-heat tube and central bolt on inlet manifold (if you have one) undone, remove carb assy, then you can get at the alternator easily and run a clean cloth over everything too.</p></blockquote><p></p>
[QUOTE="Happystamps, post: 528614, member: 14679"] Drop the engine, every time. Much easier, especially with the luxury of a removable valance. Doesn't matter to me if it takes an extra 20 minutes. Aluminium casting ends off, pre-heat tube and central bolt on inlet manifold (if you have one) undone, remove carb assy, then you can get at the alternator easily and run a clean cloth over everything too. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
