Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
High beam problems
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="montypsx" data-source="post: 598027" data-attributes="member: 16612"><p>Hi all slight problem with my high beam. If I pull the stick to flash it flashes ok and I can hear the relay however if the lights are on and I pull the stick to put high beam on they won't stop on just flash but again I can still hear the relay clicking. </p><p></p><p>I've had the switch apart and can't find owt so is it the relay.</p><p></p><p>Cheers phil</p></blockquote><p></p>
[QUOTE="montypsx, post: 598027, member: 16612"] Hi all slight problem with my high beam. If I pull the stick to flash it flashes ok and I can hear the relay however if the lights are on and I pull the stick to put high beam on they won't stop on just flash but again I can still hear the relay clicking. I've had the switch apart and can't find owt so is it the relay. Cheers phil [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
High beam problems
