Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Hot start
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="TeamBrian" data-source="post: 545536" data-attributes="member: 20175"><p>It looks light some sort of starting aid. Check, clean and remake all connections, especially that small earth to the body. Check the push on connector which goes onto the starter. Make sure it's a good tight fit. I know it's been fitted for a reason but remove it from the system and see what happens.</p></blockquote><p></p>
[QUOTE="TeamBrian, post: 545536, member: 20175"] It looks light some sort of starting aid. Check, clean and remake all connections, especially that small earth to the body. Check the push on connector which goes onto the starter. Make sure it's a good tight fit. I know it's been fitted for a reason but remove it from the system and see what happens. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Hot start
