froggy
As above how do you remove the cam gear from the crank, i need to replace the bearing.
Also whats the easiest way to re-fit the cam gear?
Yeah i know but not willing to pay £50+ for something i (hopefully) will only use once67 BAY said:The best way to remove is to use the proper gear puller
Steve
dubdubz said:I heat them up using a blow torch and use a 3 leg puller with a large jubilee clip to hold the legs together - its a long job and takes longer than I'd like.....
didn't realise you could get a tool... :roll:
