Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
If I lower by 3.5”.......
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Redbanana" data-source="post: 606980" data-attributes="member: 25369"><p>As stated by Clem, shorter shocks. You can mount the front shocks in the rear if they are in good condition, and for the front I would put some shorter gas shocks for stiffness. Also you might be looking at tubbing the front Wheel wells for clearance with those big tires. Last but not least, check clearence between rear frame and driveshaft / IRS Control arm. You can get by with just grinding the lip down and maybe trim the bumpstop a tad.</p></blockquote><p></p>
[QUOTE="Redbanana, post: 606980, member: 25369"] As stated by Clem, shorter shocks. You can mount the front shocks in the rear if they are in good condition, and for the front I would put some shorter gas shocks for stiffness. Also you might be looking at tubbing the front Wheel wells for clearance with those big tires. Last but not least, check clearence between rear frame and driveshaft / IRS Control arm. You can get by with just grinding the lip down and maybe trim the bumpstop a tad. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
