Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Indicator Fault
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="rabbie 72" data-source="post: 566099" data-attributes="member: 18280"><p>Hi Been having problems with the main beam, now fixed.</p><p></p><p>After reassembling I have developed a fault with the indicators. Hazards are working fine so relay is good. I think the problem is with indicator/main beam switch. Although it is new ish (replaced about 15 months ago). </p><p></p><p>what are peoples opinions?</p><p></p><p>If it is the switch, how can I test/check? Replace?</p><p></p><p>Thanks in advance</p></blockquote><p></p>
[QUOTE="rabbie 72, post: 566099, member: 18280"] Hi Been having problems with the main beam, now fixed. After reassembling I have developed a fault with the indicators. Hazards are working fine so relay is good. I think the problem is with indicator/main beam switch. Although it is new ish (replaced about 15 months ago). what are peoples opinions? If it is the switch, how can I test/check? Replace? Thanks in advance [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Indicator Fault
