Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Indicator relay
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mike202" data-source="post: 454339" data-attributes="member: 17202"><p>Alistair, not quite sure what you mean <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite10" alt=":oops:" title="Oops! :oops:" loading="lazy" data-shortname=":oops:" /> </p><p>the relays in my post were taken from my 1970 westy import I can only assume they are original. If you have no tell tale try doing what I did, although as I sure you will realise the dash bulbs could have gone. </p><p>Why did you have to wire in a key-in buzzer for the MOT?? :msn4: This is not a requirement.</p></blockquote><p></p>
[QUOTE="mike202, post: 454339, member: 17202"] Alistair, not quite sure what you mean :oops: the relays in my post were taken from my 1970 westy import I can only assume they are original. If you have no tell tale try doing what I did, although as I sure you will realise the dash bulbs could have gone. Why did you have to wire in a key-in buzzer for the MOT?? :msn4: This is not a requirement. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Indicator relay
