Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Indicators - flashers - fuel gauge failed ! Help !
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Trab" data-source="post: 562612" data-attributes="member: 20495"><p>You have to check THE double ground connections on THE back of gauge panel. I ve struggled with exactly THE same and replaced ralais connectors complete wiring to headlights, but iT only took 20 cm wire connection with proper clean chassis ground! Take à 2,5 wire while You're at it!! I was amazed, iT sorted out all problems at once!!</p></blockquote><p></p>
[QUOTE="Trab, post: 562612, member: 20495"] You have to check THE double ground connections on THE back of gauge panel. I ve struggled with exactly THE same and replaced ralais connectors complete wiring to headlights, but iT only took 20 cm wire connection with proper clean chassis ground! Take à 2,5 wire while You're at it!! I was amazed, iT sorted out all problems at once!! [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
