Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Insulating headers/engine bay temp
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Zcat7" data-source="post: 509335" data-attributes="member: 14023"><p>I have noticed, since fitting my 1776 into my crossover and monitoring oil temps, just how hot the rear tin gets. I have an EMPI header mated to a Bugpack box and even when I had the 1641 engine it got hot enough to fade the paint on the rear valance (it's a shite paint job to be fair...).</p><p>I was wondering about insulating the headers from the surrounding tin. I don't really want to use exhaust wrap as that will just hold the heat in the heads so I was wondering if anyone has used a reflective foil/insulation type solution attached to the tin and valance to keep the heat from soaking into the engine bay?</p></blockquote><p></p>
[QUOTE="Zcat7, post: 509335, member: 14023"] I have noticed, since fitting my 1776 into my crossover and monitoring oil temps, just how hot the rear tin gets. I have an EMPI header mated to a Bugpack box and even when I had the 1641 engine it got hot enough to fade the paint on the rear valance (it's a shite paint job to be fair...). I was wondering about insulating the headers from the surrounding tin. I don't really want to use exhaust wrap as that will just hold the heat in the heads so I was wondering if anyone has used a reflective foil/insulation type solution attached to the tin and valance to keep the heat from soaking into the engine bay? [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
