Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
General Earlybay Chat
Interior roof advice
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Graham L" data-source="post: 561816" data-attributes="member: 3481"><p>The sunroof liner is a pain even when its covered in fabric like it is from the factory, the channel it sits in is so tight that it has a tendency to stick and you cant add any lubricant as it will mark the headliner, ours also catches on the inner roof itself as it slides back leaving marks on the cloth <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite3" alt=":(" title="Frown :(" loading="lazy" data-shortname=":(" />.</p><p></p><p>I think if you cut a piece of 3mm ply to the same size/shape as the liner you could ditch the factory liner and use velcro on the front edge of the actual sunroof to hold the ply panel in place as thats the only place it fastened on the factory one so you can pop iy off and slide it back to get to the mechanism (ramps & lifters etc)</p></blockquote><p></p>
[QUOTE="Graham L, post: 561816, member: 3481"] The sunroof liner is a pain even when its covered in fabric like it is from the factory, the channel it sits in is so tight that it has a tendency to stick and you cant add any lubricant as it will mark the headliner, ours also catches on the inner roof itself as it slides back leaving marks on the cloth :(. I think if you cut a piece of 3mm ply to the same size/shape as the liner you could ditch the factory liner and use velcro on the front edge of the actual sunroof to hold the ply panel in place as thats the only place it fastened on the factory one so you can pop iy off and slide it back to get to the mechanism (ramps & lifters etc) [/QUOTE]
Verification
Post reply
EarlyBay Forums
