interior
mustard72
May 2, 2008
290
hampshire
evening all, my van is totally bare in the back. what size plywood do you all use for re-paneling the sides of the van and floor?? is it 18mm ply??
jason
9mm bottom floor 6 mm top
3mm ply for panels covered with clear satin varnish which currently won't dry cause its bloody cold! Empty bus for Stonor Park it is then!
Lee
thanks for the replies. anyone got any pics??? especially where you screw the ply to the van metal. and what size screws do you use?? ta.
jason
l used panel clips to secure mine. Can be found on eBay or JK. The holes are offset for the clips though & my panels came pre drilled. Someone on here may have some templates if you're lucky.
Got a full set of panels off a bloke called sam32blue on ebay. £85 for the set with delivery. He's cheaper than the others selling & I was happy with the quality. I slapped some varnish on mine before fitting them & think they look good. Eventually I'll get them covered the the same as the bed when I have some spare cash.
