Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Just sheared my steering column horn spade connector grrr
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Whistler" data-source="post: 514106" data-attributes="member: 18919"><p>I just used a spade connector cut from a normal wiring one. Cut just the spade, drilled a hole and used a regular rivet through the existing hole in the column. I tried to solder but it wasn't happening so just went for the quick fix <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="Whistler, post: 514106, member: 18919"] I just used a spade connector cut from a normal wiring one. Cut just the spade, drilled a hole and used a regular rivet through the existing hole in the column. I tried to solder but it wasn't happening so just went for the quick fix :) [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
