Picked up my bus from Midland Early Bay on Friday - have to firstly thank Graham and Gadget for all their work getting it purchased, imported and registered - the whole process was slick and I made the trip back from the Midlands to Cambridge (2 1/2 hours) without any issues and gave me plenty of time to get used to the left hooker and changing gears! (my daily is an automatic and have been a convert from manual for a few years now!)
Here she was as I arrived at MEB - just getting some finishing attention:
And thankfully post a gentle tap from Gadgets lowering stick with adjusters and 1 spline on the rear it fits in my garage :mrgreen:
After collecting it, taking it home and putting it in the garage it hasn't moved this weekend and sods law dictated that I had a christening to go to and helping a mate on his extension
- did manage to get to work on a few little things I picked up on:
Connected the rear running lights back up
Fixed the rear interior light
Fixed the cab light (both from corroded terminals that needed a scrape)
Fixed the main/dip headlamp dash lights
Fixed the Oil warning lamp
Cleaned the coating from the white walls and they've come up well
Trial fitted the carputer screen (chuffed as the laptop fits in the glovebox!) 8)
Also installed a plugin for centrafuse which includes a speedo calculated from GPS data which will be nice to check with the cable speedo for accuracy, that and a fuel calculator to see what mpg I'm getting at the moment,
As it happens recently found out 400 yds down the road from me is a company called "VW Technics" who after a call are up on air cooled engines - so it's going in for the timing & an oil change next week and that will give me time to work on other bits (need to buy a timing light!) - list at the moment is:
Clean & hoover out the interior
Give it a good wash, t-cut and polish
Fit leisure system
Fit mains hookup and consumer unit
collect and fit double roof bunk
Connect front running lights to indicators
Fit carputer, amp, video camera & rear monitor
Going to run it for a bit and see what else comes up - confirmed that the engine looks pretty new and all mechanics seem to be in good shape
