72baywesty said:Early 5 x 205 14 inch wheels wont fit on late bay discs even with 25mm adapters as the caliper is in the way of the rim. Supposedly you can grind the caliper to make it fit however I tried it with an old caliper and no way was it going to work.
ozziedog said:72baywesty said:Early 5 x 205 14 inch wheels wont fit on late bay discs even with 25mm adapters as the caliper is in the way of the rim. Supposedly you can grind the caliper to make it fit however I tried it with an old caliper and no way was it going to work.
This is possibly one of the reasons that wide 5 15” wheels are very popular. I do know of one early with discs and fourteen inch wheels and I’m guessing there’s more about, but split 15” wide 5s should make it easier.
Ozziedog,,,,,,,,,, hub caps for the win :mrgreen:
72baywesty said:ozziedog said:72baywesty said:Early 5 x 205 14 inch wheels wont fit on late bay discs even with 25mm adapters as the caliper is in the way of the rim. Supposedly you can grind the caliper to make it fit however I tried it with an old caliper and no way was it going to work.
It's possible.... but you have to remove lots of caliper where the thru bolts fit leaving only a couple of threads holding the caliper halves together not exactly ideal.
