user 20733
- Joined
- Feb 25, 2014
- Messages
- 236
- Reaction score
- 0
This has been posted on Latebay too, so if you are on both forums, you may recognise this thread.
I have twin ICT34s. They run fine, but the top gasket gets wet with fuel, especially when first switched off. I'd does not drip down the carbs but after a while dries out.
I have fitted a filter king regulator and it is set to 2.5psi. I have also replaced my mech fuel pump as is was dying.
To make matters worse, I forked out for some new carbs and they are doing the same thing.
I have checked the float levels and replaced the gaskets several times. I have even doubled them up to make sure they seal all the way around. I do fit them dry.
I do have a fuel cut-off solenoid fitted near the tank, wired to ignition.
Has anyone else had this problem? Any suggestions? Thanks.
Sent from my iPad using Tapatalk
