Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Leisure battery sizes
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="montypsx" data-source="post: 602324" data-attributes="member: 16612"><p>It all depends on what size your starting battery is an what type of split charger your using.</p><p>If you have an 85 amp hour battery to start your van and you put a 110 amp leisure battery in it will only charge to 85amp and when the starter battery gets full the alternator switches off.</p><p>So fit two batteries the small size or get a really good split charger that can monitor both batteries but they aren't cheap</p></blockquote><p></p>
[QUOTE="montypsx, post: 602324, member: 16612"] It all depends on what size your starting battery is an what type of split charger your using. If you have an 85 amp hour battery to start your van and you put a 110 amp leisure battery in it will only charge to 85amp and when the starter battery gets full the alternator switches off. So fit two batteries the small size or get a really good split charger that can monitor both batteries but they aren't cheap [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
