Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Losing spark when hot
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Hubs" data-source="post: 608137" data-attributes="member: 17993"><p>If you have an electronic contactorless (no points) ignition then that could be its way out. They seem to fail gradually which makes them pita to fault find. Generally playing up more when hot. Most of the budget replacements in the last year now have improved the electronics. Get one that turns it self off after 1 second if the engine is not running. This prevents you cooking them when you leave the ignition on.</p></blockquote><p></p>
[QUOTE="Hubs, post: 608137, member: 17993"] If you have an electronic contactorless (no points) ignition then that could be its way out. They seem to fail gradually which makes them pita to fault find. Generally playing up more when hot. Most of the budget replacements in the last year now have improved the electronics. Get one that turns it self off after 1 second if the engine is not running. This prevents you cooking them when you leave the ignition on. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
