Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Lowering without notching, parts needed?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ozziedog" data-source="post: 602014" data-attributes="member: 13810"><p>Try to his one for size.</p><p></p><p>http://forum.earlybay.com/viewtopic.php?f=4&t=45111&hilit=Lowering+gurus</p><p></p><p>The up shot is, you can go about two and a half to three inches lower on the front with Transporterhaus lowered spindles with flipped ball joints, you’ll need some custom coil overs to help with the springing. After that you can gain another half an inch or maybe up to an inch and a half with some lower profiled tyres but check they are up to the weight. Anything more than this and you’ll need a King and link pin old style beam then we start talking about notching and tubbing etc etc. Go a bit careful because it does get a bit addictive for some <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite2" alt=";)" title="Wink ;)" loading="lazy" data-shortname=";)" /> </p><p>http://forum.earlybay.com/viewtopic.php?f=4&t=45111&hilit=Lowering+gurus</p><p></p><p></p><p>Ozziedog,,,, that can be your bed time reading for a week I guess :mrgreen:</p></blockquote><p></p>
[QUOTE="ozziedog, post: 602014, member: 13810"] Try to his one for size. http://forum.earlybay.com/viewtopic.php?f=4&t=45111&hilit=Lowering+gurus The up shot is, you can go about two and a half to three inches lower on the front with Transporterhaus lowered spindles with flipped ball joints, you’ll need some custom coil overs to help with the springing. After that you can gain another half an inch or maybe up to an inch and a half with some lower profiled tyres but check they are up to the weight. Anything more than this and you’ll need a King and link pin old style beam then we start talking about notching and tubbing etc etc. Go a bit careful because it does get a bit addictive for some ;) http://forum.earlybay.com/viewtopic.php?f=4&t=45111&hilit=Lowering+gurus Ozziedog,,,, that can be your bed time reading for a week I guess :mrgreen: [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
