Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Modification to make beam flasher work
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="matbow" data-source="post: 605842" data-attributes="member: 14867"><p>My 1969 US bus would only flash with the lights on. To modify this so I could flash the headlights with the lights off I wired in a 12v 30 amp auxiliary relay with a small blocking diode as per the diagram below. It works fine on my bus and I did not have to chop any wiring or replace my dip relay. Looking at later US diagrams it should also work for them. I hope the diagram below opens ok, on the plus side it only cost a few quid and took about half an hour with no wire chopping.</p><p></p><p><a href="http://s1319.photobucket.com/user/matcarbow/media/DipRelayMod_zpsedcb70ca.jpg.html" target="_blank">http://s1319.photobucket.com/user/matcarbow/media/DipRelayMod_zpsedcb70ca.jpg.html</a></p></blockquote><p></p>
[QUOTE="matbow, post: 605842, member: 14867"] My 1969 US bus would only flash with the lights on. To modify this so I could flash the headlights with the lights off I wired in a 12v 30 amp auxiliary relay with a small blocking diode as per the diagram below. It works fine on my bus and I did not have to chop any wiring or replace my dip relay. Looking at later US diagrams it should also work for them. I hope the diagram below opens ok, on the plus side it only cost a few quid and took about half an hour with no wire chopping. [url=http://s1319.photobucket.com/user/matcarbow/media/DipRelayMod_zpsedcb70ca.jpg.html][/url] [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
