Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
General Earlybay Chat
Moon Speed master wheels?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Matt Maz" data-source="post: 566316" data-attributes="member: 1778"><p>I bought some genuine Speedmasters from Biaggio a couple of months back...hopefully they will be on by the end of the week!!</p><p></p><p>The ET is rubbish though as others have mentioned. Mine are the ET13, I should have been more patient and ordered the ET21. My bus is pretty low but with a 4'' narrowed ball joint beam I couldn't fully drop the bus as they fouled the tubs.</p><p></p><p>I've got a 4.5'' King and Link beam going on which hopefully will sort that issue out.</p><p></p><p>I'm unsure about the SMA wheels from midland wheels as they are 5.5J whereas the genuine speedmasters are 5J so the SMA's may be even harder to get to fit. Having said that I guess if the bus isn't stupidly low they may fit without too much work?</p></blockquote><p></p>
[QUOTE="Matt Maz, post: 566316, member: 1778"] I bought some genuine Speedmasters from Biaggio a couple of months back...hopefully they will be on by the end of the week!! The ET is rubbish though as others have mentioned. Mine are the ET13, I should have been more patient and ordered the ET21. My bus is pretty low but with a 4'' narrowed ball joint beam I couldn't fully drop the bus as they fouled the tubs. I've got a 4.5'' King and Link beam going on which hopefully will sort that issue out. I'm unsure about the SMA wheels from midland wheels as they are 5.5J whereas the genuine speedmasters are 5J so the SMA's may be even harder to get to fit. Having said that I guess if the bus isn't stupidly low they may fit without too much work? [/QUOTE]
Verification
Post reply
EarlyBay Forums
