Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
MOT failure. Help!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Toad" data-source="post: 124684" data-attributes="member: 7670"><p>Its not a bad job actually. You can get pretty good access to it and it should all drift out ok (pin,bushes).</p><p>Just need to make sure that when you put the top arm back on that you get it lined up correctly or the thread on the pinch bolt will get damaged.</p><p>Good luck</p><p>M</p></blockquote><p></p>
[QUOTE="Toad, post: 124684, member: 7670"] Its not a bad job actually. You can get pretty good access to it and it should all drift out ok (pin,bushes). Just need to make sure that when you put the top arm back on that you get it lined up correctly or the thread on the pinch bolt will get damaged. Good luck M [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
MOT failure. Help!
