shea said:thanks, so the above is just spacers? I was told I need brackets for the shocks to work, I'm just off the phone with T2D who said the extenders (I take it extenders are the brackets?) are needed to get a proper lift from the shocks. They said the extenders are £125 delivered which is expensive enough I think
Clem said:shea said:thanks, so the above is just spacers? I was told I need brackets for the shocks to work, I'm just off the phone with T2D who said the extenders (I take it extenders are the brackets?) are needed to get a proper lift from the shocks. They said the extenders are £125 delivered which is expensive enough I think
Those are what I bought. Not for air shocks but to get my Gaz shocks into alignment. They are expensive, and if you had the materials, equipment, skillz and dimensions they could be made, but, if youre missing any of them, then thats what they cost :lol:
shea said:Clem said:shea said:thanks, so the above is just spacers? I was told I need brackets for the shocks to work, I'm just off the phone with T2D who said the extenders (I take it extenders are the brackets?) are needed to get a proper lift from the shocks. They said the extenders are £125 delivered which is expensive enough I think
So extenders are needed for gaz coilovers too? the shocks and extenders come to £225 so was thinking I might as well get the gaz coilovers but not if they also need extenders.
I know what you mean in regards to the price of the extenders I'll probably end up getting them in the end but I'm going to shop around first as I know a few companies are making them.
gvee said:Which ones are those, Clem?
Do the arms need any modifications with either this or the VolksProject ones, or do they just bolt [and weld?] on?
shea said:it pushes the bottom out around 1.5 - 2 inches I'd say, maybe less. I'm wondering if the advice I've been getting about needing an extender have been based on other beams that have a top shock mount that's further back?
My creative weed eater beams top mount isn't that far back and that's why the shock is straighter when bolted on the original bottom mount.
I won't be at my bus for a week or so but when I get back I'll measure the lift with and without extenders at say 110 psi and report back
