Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
If you have bought, sold or gained information from our Classifieds, please donate to Early Bay and give back.
You can
become a Supporting Member
or just
click here to donate
For Sale & Wanted section
Early Bay Parts for Sale & Wanted
new cab headliner
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Diddymen" data-source="post: 481707" data-attributes="member: 16856"><p>Hi Jamie,</p><p></p><p>Does your cab headliner have the 'grips' to the rear, level with the B'posts ....if so the ones we have on the shelf will fit and you will just need the material for the sides and rear</p><p></p><p>.....if it doesnt, we can always make one with an extended rear piece without the fixing strip attached to the cab headliner.</p><p></p><p>Did you want enough material to go from the poptop opening, around the windows and down to the door cards? .....with a bit extra for the rear section of the roof?</p><p></p><p>The sides (from B post to tailgate) are approximatly 282cm, and you would need about 80cm height.</p><p></p><p>based on the above you would probably need the cab headliner and an additional 5-6Mr of material, depending on how you cut and install the sides and rear.</p><p></p><p>for the standard cab headliner and additional 5mr of material would be £150 including P&P, add another £10 if you need 6mr</p><p></p><p>Obviously, I would reccomend you measure your van first to be sure of how much extra you need, as I wouldnt want to supply you with something or quantities you are not happy with.</p></blockquote><p></p>
[QUOTE="Diddymen, post: 481707, member: 16856"] Hi Jamie, Does your cab headliner have the 'grips' to the rear, level with the B'posts ....if so the ones we have on the shelf will fit and you will just need the material for the sides and rear .....if it doesnt, we can always make one with an extended rear piece without the fixing strip attached to the cab headliner. Did you want enough material to go from the poptop opening, around the windows and down to the door cards? .....with a bit extra for the rear section of the roof? The sides (from B post to tailgate) are approximatly 282cm, and you would need about 80cm height. based on the above you would probably need the cab headliner and an additional 5-6Mr of material, depending on how you cut and install the sides and rear. for the standard cab headliner and additional 5mr of material would be £150 including P&P, add another £10 if you need 6mr Obviously, I would reccomend you measure your van first to be sure of how much extra you need, as I wouldnt want to supply you with something or quantities you are not happy with. [/QUOTE]
Verification
Post reply
new cab headliner
