froggy
Took the van out for a drive over the weekend (was planning on going to Stonor) and to be totally honest the van has no get up and go, show it any sort of hill and you might as well get out and walk.
Timing is spot on, carb (30 pict 2) is re-conned and set up according to solex, points correctly adjusted, valves adjusted (numerous times).
Engine revs fine (and now also idles at junctions) but put your foot down and forget it, pulls well in 1st and not to bad in 2nd but 3rd and 4th forget it, struggles to get above 45mph wind assisted down hill foot flat to the floor.
Very Very dis-appointed with it.
Planning on doing a compression test and take it from there but any other ideas?
