O.K. so out with the single carb and in with the twin carb. While this was happening all of the HT leads came off. Now it's all back together she's not running on No.1 or 3 cylinder. I've worked this out by pulling of the HT leads, removing 2 or 4 the engine slows and runs even rougher, removing 1 or 3 (or both) no change. By connecting 1 HT lead to 3 position and giving a bit of a rev will induce a bit of a pop from the exhaust. I've swapped spark plugs between 2 and 3 with no change.
Before this work the engine was running sort of OK but the single carb was way past its best hence the upgrade to twins. The only other thing is the bus has been parked on a slope of about 15 deg (nose down) could the oil sitting at the front of the engine be a problem? When the spark plugs were removed to swap them over they both looked the same (a bit black from running rich with the single carb).
Over to you dudes, I'm sure one of you will have more of an idea than me.
Arran.
Arran.
