Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
number plate gloop
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="vinvan" data-source="post: 597295" data-attributes="member: 20001"><p>They are usually stuck on with double sided tape, first try a heat gun(not to hot) if the plate comes off and there is any residue left on the paintwork try some WD40, spray some on the residue leave for a couple of mins then scrape off with a soft piece of plastic (like the ones used for body filler) take your time</p></blockquote><p></p>
[QUOTE="vinvan, post: 597295, member: 20001"] They are usually stuck on with double sided tape, first try a heat gun(not to hot) if the plate comes off and there is any residue left on the paintwork try some WD40, spray some on the residue leave for a couple of mins then scrape off with a soft piece of plastic (like the ones used for body filler) take your time [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
number plate gloop
