Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Oil filed air filter question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="fozworth" data-source="post: 556437" data-attributes="member: 20087"><p>Unless I drill out a 50mm hole in my freshly powder coated front tin I don't have a hot air pickup pipe .only the heat risers .i guess I will have to see how it runs and if need be carefully cut a 50mm hole out</p></blockquote><p></p>
[QUOTE="fozworth, post: 556437, member: 20087"] Unless I drill out a 50mm hole in my freshly powder coated front tin I don't have a hot air pickup pipe .only the heat risers .i guess I will have to see how it runs and if need be carefully cut a 50mm hole out [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
