YellowBay69
- Joined
- May 27, 2019
- Messages
- 342
- Reaction score
- 232
- Year of Your Van(s)
- 1969
- Van Type
- 1969 Bay Window
Don’t normally do this kind of thing as I’m no expert - but…
Was struggling to undo the cap on the oil pressure relief valve. So created a simple tool to do the job with stuff i had lying around.
Used a 22mm hole cutter cut down to fit in 19mm impact socket.It only needs to protrude 2-3mm (depth of slot)
Give the cap a sharp tap - then ease off .
Worked a treat !!
So if you’re a driveway mechanic and struggling with this job try it.
Worked a treat !!
