Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Removing old paint
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Happystamps" data-source="post: 539641" data-attributes="member: 14679"><p>Well, you've started something there, haven't you.</p><p></p><p>So what was the original colour? </p><p></p><p>You're going to want as good a finish as possible, I'd get a polishing machine (£50-ish new) with a big fluffy bonnet, and first off use your thinners on that to get the green off. You've got a lot of area to cover, hence the machine. You'll possibly want gloves with an area that big, or your arms will go numb pretty quickly!</p><p></p><p>Then I guess- and it'll take a while! replace the polishing bonnet and use cutting compound, T-cut style stuff. There's undoubtedly more aggressive stuff out there that might well be worth looking into.</p></blockquote><p></p>
[QUOTE="Happystamps, post: 539641, member: 14679"] Well, you've started something there, haven't you. So what was the original colour? You're going to want as good a finish as possible, I'd get a polishing machine (£50-ish new) with a big fluffy bonnet, and first off use your thinners on that to get the green off. You've got a lot of area to cover, hence the machine. You'll possibly want gloves with an area that big, or your arms will go numb pretty quickly! Then I guess- and it'll take a while! replace the polishing bonnet and use cutting compound, T-cut style stuff. There's undoubtedly more aggressive stuff out there that might well be worth looking into. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Removing old paint
