Repair sections for Front - Best = who these days?
dubdubz
Jul 10, 2007
2,531
2
Peterborough mainly never Cornwall
So not welded up anything bus shaped for 10 + years but the 68 will need a repair or 2 under the screen and also the very bottom valance bit is looking bubbly on the very edge
as I intend to do it properly and only once in my ownership - who makes the best panels for these locations?
or do I speak to someone like FBI and get an original section cut?
thanks in advance
ozziedog
Jan 24, 2010
6,153
79
East Brizzal
I’ve got the repair sections brand new from one of the suppliers. It’s just so much tosh. I’d get an original cut if you can. I cut out each tiny rusted section and made pieces to weld in and did it slow to finish continuous and buff out. While you’re piddling about down there, might be worth moth balling your original screen and getting a laminated one because the toughened one can be a liability and the recovery companies aren’t sympathetic to shot screens. Worse case scenario with a laminated one is a crack but you still get home without frostbite :lol: if it’s a bad bad section, then get a cut otherwise make sections from good original steel :mrgreen:
Ozziedog,,,,,,,,,and get sorted soon cus summers on its way :mrgreen:
ozziedog
Jan 24, 2010
6,153
79
East Brizzal
It should say down in the corner I think, but maybe only if it’s laminated, I’d have a good look but you can tell laminated usually when looking at the edges, not sure if that’s after a cut though.
Ozziedog,,,,,,, more research needed I think :mrgreen:
dubdubz
Jul 10, 2007
2,531
2
edge on is easy - can't get to the 'spare' to compare
I cannot think the one is original that is in it, but I'll have a check in the morning..
ozziedog
Jan 24, 2010
6,153
79
East Brizzal
I guess you could look at the rear, which will be toughened and if you can see the dots with your Polaroid’s on, you could then hold the screen in a similar position to verify.
Ozziedog,,,,,,,,,, just get a new one on insurance! :mrgreen:
dubdubz
Jul 10, 2007
2,531
2
As we all seemed to have a science fiction stasis/sleep for 2 years. I’m going to do these repairs this year now.
I did some Sunday night research and was shocked on the lack of options. Which I figure is probably me not looking properly.
Going to ring fbivw, see what they have…I do wonder if the surface rust I can see will have also mullered the inside valance panel too, but won’t know until I look. I do have a usb endoscope that may help here before I cut huge chunks off!
So panels, who best in 2022?
Graham L
Jan 19, 2008
5,180
83
Redditch
We only buy repair panels from Schofields and always buy the best quality ones available, they offer the 3 piece repair for under the screen but it’s often easier to go for the upper panel repair se room which includes the bulge. For the lower section they make their own inner and outer lower valance which are good.
orpheusvw
Active member
Apr 2, 2010
25
I’ve always thought that Klassic Fab panels were the best and nearest to OG you could buy, they used to do a panel that was just the bulge under the windscreen but C&C don’t appear to have that in stock at the mo, just the lower 11 inch. Mine turned out to just be some some holes under the windscreen when it was cleaned up, so I made some little repair pieces and welded them in instead of replacing the lot, might not be as bad as you think until you get it cleaned up?
dubdubz
Jul 10, 2007
2,531
2
Thanks Graham really useful
dubdubz
Jul 10, 2007
2,531
2
Klassicfab was my first thought and I followed the same route as you described.
leon
Feb 1, 2007
1,333
57
Stafford
Year of Van
1969
Van Type
Westfalia
Agree with Graham. I've used both funky green and Schofield's. Both are good, but Schofield's are more easily available.
Camperdan
Apr 2, 2007
455
8
Berkshire
It was several years back but I used the Classic Fab funky green bulge section when I did mine... The guage and shape were pretty good... However I ended up having to cut it down and use just the very top part because either the positions of the holes for the washer jets or the wipers were not in the right place... can't remember which? Think it might have been a lhd versus rhd issue?
So something to look out for if you do go that route.
