Replacing a Red 9 Design EZ Rider front beam - choices
VeeDubMan
Feb 16, 2008
717
Reading, Berkshire.
I've had one of the original Red 9 Design EZ Rider front beams on my '71 for the past 12 years or so. It was the 2"-4" drop version. It gives a nice ride quality with an uprated anti-roll bar too, but at the last MOT, I had discussions with the tester about some travel in the trailing arms he'd noticed. Almost looks like the inner part of the trailing arm inside the torsion tube has some movement. Is there an inner bush in the tube as well as the outer bearing? Is that replaceable?
If not, I'm tempted to go back to torsion leaves (stock width beam). Any differences between the beams that are now available? Limebug looks comprehensive but also looks like there are many other choices out there too. Not looking to go super-low (need to get across un-even campsites reliably!) and keeping stock width.
VeeDubMan
Feb 16, 2008
717
Reading, Berkshire.
Ha! Just found my original post about the same issue. Looks like I've always had the problem then but never failed an MOT because of it:
https://earlybay.com/threads/do-torsion-arms-wear-in-the-tubes-red-9-beam.65350/
mike202
Sep 3, 2011
2,248
211
Northumberland
In your earlier post you say you have contacted Red9. Did they respond?
Do you mean play in the trailing arms ? I suppose to fail the MOT it would have to be quite bad
VeeDubMan
Feb 16, 2008
717
Reading, Berkshire.
Yeah, they sent me a couple of new 'through bars' (the things they use to replace the torsion leaves) but they didn't make any difference.
Not sure if you can see the videos in the Dropbox, but they show the play.
[email protected]
Sep 8, 2008
4,944
362
Felixstowe, Suffolk
Year of Van
1970
Van Type
Westfalia pop-top
LOCATION
Suffolk wilderness
If you go the new beam route speak to Transporterhaus, he’s not always the fastest to reply but nothing comes close to his stuff.
MarcE1969BayBlue
New member
Jun 26, 2021
2
Cool Air are now stocking Transporterhaus products. Most available off the shelf.
Massive relief as like you say, Alex is a little slow to reply. 😬
Graham L
Jan 19, 2008
5,233
139
Redditch
If you are just looking to go back to a stock beam and width then the one JK sell is of good quality and that linked with late bay dropped spindles will give you a similar ride height to a red 9 kit, you’ll have to run late bay discs and calipers ( which you may have already from the red 9 set up)
We’ve got sets of used leaves here if you need them.
